This Toyota Yaris GR 2020 G16E package is based on MoTeC's successful GPRP-DI package and is available on the MoTeC M142 ECU, it is a versatile and adaptable platform for the operation of this engine.
It is configured to run the Toyota Yaris G16E Engine with the addition of a paddle shifted gearbox using switched actuators. The package allows for easy changes to engine tuning and hardware.
Along with fuel, ignition, throttle and camshaft control, this package also supports other OE ECU features, including:
- Selectable Drive Mode including Normal, Sport, and Track using OE controls
- Head-Up Display
- Direct injector with high pressure fuel pump control and secondary port injector control (saturated high-ohm injectors only)
- Cruise control
- All OE dash functionality including warnings
